MAX On-The-Go with SpeedFusion WAN Smoothing (3G)
  • Multi 3G Router
  • 4x USB, 1x ETH
  • Support for Load Balancing & SpeedFusion WAN Smoothing
  • 802.11n Wi-Fi AP
Product Code: MAX-OTG-U4-SF
Additional Info
Additional Info
Product Code MAX-OTG-U4-SF
WAN Interface 4x FE
Wi-Fi Interface 802.11a/n or b/g/n Wi-Fi as WAN and AP (supports only one of 802.11b/g/n and 802.11a/n Wi-Fi)
Embedded 4G LTE/3G N/A
USB WAN Modem 4
LAN Interface 1x FE
Recommended Users 1-25
Router Throughput 100Mbps
Data Rates 2.4GHz: 150Mbps or 5GHz: 150Mbps
Disk Drive N/A
Load Balancing & Failover Yes
PepVPN Yes
SpeedFusion Hot Failover Yes
SpeedFusion WAN Smoothing Yes
SpeedFusion Bandwidth Bonding N/A
Number of PepVPN/SpeedFusion Peers 2/ 300 (Supports 2 PepVPN peers. With purchase of optional SpeedFusion License, MFA-500-A can connect to up to 50 SpeedFusion peers.)
PepVPN/ SpeedFusion Throughput 40Mbps (No Encryption); 20Mbps (256-bit AES)
Built-in AP Controller N/A
Maximum Number of AP Support N/A
PoE Input N/A
PoE Output N/A
Dimensions 110 x 110 x 30 mm
Gross Weight 0.55 kg
Package Content MAX On-The-Go
12V2A Power Supply
Firmware and User Manuals download
You may also be interested in the following product(s)
